This heavy duty liquid wax was originally developed for use by electric power companies for protection against high voltage power failure, fires and explosions. Its primary use is on the finishes of automobiles, trucks, buses and airplanes where durability, high gloss and lasting protection are paramount. An excellent choice for fleet applications and very easy to use--requires minimum rubbing or buffing.
Because of the above factors, when it is used on a cars clearcoat it leaves a very high gloss 'wet look', almost indestructable protective coating. It provides such a strong protective barrier preventing the adhesion of foreign elements and assures full protection against sun, rain, saltspray, bugs, dew, birds, smog, etc...
Clear coat safe.
Extremely durable, one application can last as long as a year.
Wet look finish
Collinite 845 Insulator Wax is best suited for lighter colours and those wanting maximum durability. This wax is an absolute steel and often over looked because of it's bland packaging. However it's easy to apply looks good and will outlast just about all other car waxes.
The Super Spray is a fantastic cost effective way of pre-washing your vehicle before washing with a mitt or sponge. Simply connect to your hose, turn the dial and cover the car in a rich , thick layer of suds. We've found using this device it not only reduces time whilst washing but makes it safer and more effective.
These Ultimate German Applicators by Lake Country are very much like their Sonus counterparts. They comprise a dual sided oval shaped applicator ideal for both polishing and finishing paint by hand.
Using the same foam as found in some of their machine polishing pads they comprise a harder white polishing and thinner red finishing foam.
The thicker white side is a pre-polymer (non exploded) cell structure which is designed to specifically work with all modern polishes. The pad is firm enough to allow polishes to be worked agressively enough to actually break the polish down reducing the risk of dullness and hazing. We have found it possible to use polishes that traditionally had to be applied by machine by hand using this pad!
The thinner red side incorporates a reticulated (exploded) 99% open cell structure.This makes it absolutely perfect for applying thin even coats of waxes and sealants.
Use these pads for polishing and applying sealants and glazes.
Car Pro Trio
The kit comprises a Ultr Fine, mild and a medium grade detailing clay in the same pack. The clays themselves are a really nice texture and a nice touch is that each clay bar comes in a individual case within the main outer case.
The Purple Monster XL is a Premium Heavy weight 600gsm monster of a towel. It is extremely absorbent, super plush and super soft.
The Purple Monster XL towel is the perfect plush drying towel, sucking up many times its own weight in water. The fibres on this towel are amongst the most water absorbant we've ever tested and as a result quickly and effortessly soak up water.
What really makes this towel stand out against the competition is it?s unique ultra sonic cut borderless edge, guaranteeing it is scratch free even on the most delicate of paints.
Optimum Opti-Bond Tire Gel gives unbeatable shine and protection in a water-based, VOC-free formula! Opti-Bond Tire Gel is a thick, water-based formula that provides high gloss shine and great durability on all tires, wheel wells, interior and exterior trim, vinyl, and dashboards. Apply Opti-Bond Tire Gel anywhere you want a high gloss shine! Opti-Bond Tire Gel delivers optimum performance and shine to all rubber and vinyl surfaces!
Optimum Poli-Seal is the most remarkable, all-in-one product ever produced! This zero dusting, buttery-smooth formula is the ultimate, one-step product. It creates gloss and long term protection that is second to none. Optimum Poli-Seal contains micro abrasives that eliminate (not hide) minor surface imperfections. It provides swirl mark removal, the final polish and a durable wax/sealant?all in one step! Poli-Seal creates a perfect shine on all types of paint, fiberglass, gel coat and smooth molded plastic. A single application provides "optimum" protection for your vehicle that lasts for months!
And Finally a bag for Porter Cable 7424XP
InshaAllah I'm going to use these in coming days and will post pictures as well
Really happy with the stuff
Thank You Allah Mian G
Sent from my iPhone using Tapatalk
