@omarabdullah022
Turtle liquid clay is a great product. I have positive reviews in its favour. Note : It is not a replacement for a clay bar, it is a superb pre wax cleaner, that is easy to use and effective..Liquid clay bar is a 3 phase liquid which contains strong cleaning agents, lubricants and soft clay polishing agents. The combo of the cleaning agents and lubricants allow it to strip off the old finish, remove embedded dirt that is stuck into the paint . Note : You have to use it with pressure, I mean dont just swipe the cloth on car, insert force and swipe while forcing it towards the surface. As per my experience, panel to panel is the way to go. After using LC on 1 panel , rinse the panel with water along with a clean MF cloth to completely remove the LC from the panel. Just rinsing with water would not rinse off the LC completely.
NOT to forget Liquid clay is the STEP 1.. Step 2 is the Clay Bar. So its not to be used alone and make a review about it.. It needs to be followed by a bar. Now after both steps the car finish is super clean!! and would secure 1st position in the baggy test !.
P.S : The bottle needs to be shaked very very well to mix the 3 layers. And shaken each time you pour the Liquid on the cloth or directly to the panel..
The panel needs to be wet , before using LC. Never use it on dry panels..
