Yes Aamir bhai presoak has to be diluted with water, for economic purposes....it`s for Rs.550 for half a litre......an I still have my half litre despite numerous engine jobs an countless undercarrige details.......even did the interior once with it............but remember this is only a cleaner...you have to dress your engine afterwards with it..... heres the original review an how to on it
Finally got time to test it, here we go...
Product : Turtle Wax Frictionless Pre Soak
Price: : Ill do a lil maths here, it
s around Rs.1,100 a litre, to use it you must dilute it with a mixture ratio of 1:5 with water, so technically yer getting 6 litres of solution. Now i reckon 200 ml is enough for a car`s underbody and engine, so 6000ml (6litres)/200ml = 30 washes, now if you divide the cost over the number of washes you get Rs.1,100/ 30 (amount of washes)= Rs.36.66, round off to 40 measly bucks for this amount of cleaning power is ridiculusly insane.
Bought From: My trusted supplier for all turtle wax products Saca Auto, Montgomery Road,Lahore.
Rating:10/10
Good: Good is everything, i mean i had a clean engine, or so i thought, an remember my cloth going black in a matter of few minutes from the dust, removed all sorts or corrosion over steel, plastic and rubber even the aluminium piping for ac gas an stuff, simple words to sum up is magic! Ive seen clean, but this was outta da world....addictive i dare say.
Bad: You mad??? Nothin!!!!!!!!!!!!!!!!!!!!!!!!
Experience: Havent used anything of this scale before, it`s the must have for your engine an underbody cleaning. PERIOD!!!!
Pre-soak is to be diluted in 1 / 5 or more water solution......bascially this is for automated car wash units, just fill yer water spray bottle with 3/4ths or more with water,add some presoak an then just spray over the area you want to clean an rub it, hose off......nothing more, nothing less, for engines I used less that even 1/5th mixture......same mixture you can use in a lota or bottle for undercarrige spray using compressed air, local method of our karigars. But dont use too much pre-soak, wont remain cost effective, an dilute only the amount you will be using, keep the rest undiluted and safe in a bottle.
