Aamir bhai Masha`Allah the results are toppppp classss!!!! Guess you lived upto your signature!!! Waxed Buffed !!!
Depth in colour by a gooood natural wax an the surface be prepped properly before hand....clay it to remove impurities...an then wax it out....
Touchup with wet sanding is the only solution if primer is peeking through, if not then have Khurum bhai buff it out!!
Ofcourse bro.........you want to wax sand grains on yer car?? You need to have a clean surface for the wax to give any sort of result an to avoid swirling up your car.....gandi gari koi bhi koi wax karta hai yar??
Have some paint of the same colour made an apply it in the scratch with a fine brush, give it a couple of coats an then wet sand it to remove excess paint you might have put on the panel, comp it, an wax it, wallah, back to good as new!!
Alllllllllllllllllllllllllllllllllllllaaaaaaaaaaaaaaaaaaaaaaaa.......................dodo wali baat mujay thora sa shak hai
kiya yeh khulaa tezad nahin hai ??? Nice work brother, Masha`Allah allllllla shine !!!
