My bad, this forum has problems sending me e-mail updates even though I am subscribed.
Try this, get a high quality microfiber and Meguiars Ultimate Compound, dab a little on the microfiber until it absorbs it (your only using the tip of the microfiber and your index finger for polishing), use a bit more so that the microfiber doesn't allow any more in (This step is called pad priming).
Then using concentric circles start polishing one panel at a time, do a bit by bit. Your hands are going to get tired and so will your patience but it will be all worth it in the end. Use water as lubrication if you feel the polish is drying out, apply more polish and change the piece of microfiber your using every 10 cm by 10 cm square.
You will have to wash and clay the panel before polishing it, this is the only way to truly get swirls. After you polish you will need to put a sealant or wax on the specified area because polishing removes all protection.
Give me 2.5 months and I'll tell you what I am blabing on about:P.
