Okay the way I recall...you are good with pastes...stick to pastes as your first stock up...
Wax...3M perfect it...I am not recommending GC here as GC requires surface prep and we need to get you into that first...
CLEANER Wax...you need to step up and get into the surface prep game...get yourself a Megs cleaner wax...not so heavy on the pocket either
Shampoo...get Armor All or ICE...
Swirl remover...well you dont really need it...you can get rid of light swirls with Megs cleaner wax and for the heavy ones you can use compound...and then maintain it with the cleaner wax
Detailer....you forgot this...Armor all is good and turtle platinum is good...read my post on detailers posted on 25th of this month for more info
Interior Protectant...I use Megs NXT tech interior protectant...works really fine...
Plastic cleaner for headlights...use a detailer...unless your lights are totally messed up
Compound...I guess V1 will guide as to which compound should you play around with at this point in time...
Glaze: again, you forgot this...get V1 to help you out...but for the time being cleaner wax can work as well....
There are few things more...but if you currently just stick to a cleaner wax and a good follow up coat with lets say 3M perfect it...you are good to go...control these two before you add in more stages...
Oh yes...a tyre gel....for matt finish go for Armor All tyre foam and for glossy...go for megs endurance gell....
hope this helps....
