Items needed:
Chua motor or normal water tap with normal pressure
Water hose
Gas nozzle which is used to attach plastic pipe with the steel pipe
Jubilee clip in case the connection is loose
Now fix the gas nozzle in the pipe mouth as illustrated in the pic. if it is loose n tends to come out with water pressure then apply jubilee clip.
All set now connect the other end of the pipe to water tap or chua moter and jinga lala you have a pressure washer just in 30 PKR
The above pics were taken when the source was normal water tap as shown below
Pressure with chua motor was so immense that it made the pipe dance like crazy. it also tried to give a wash to my phone while I was trying to snap it as it was swirling around ,so no photo available while the source was chua motor.
In sha Allah will try this DEVICE on my car and will post the feedback.
Positive/negative comments invited/welcomed.
Regards
