Order Placed - Awaiting Delivery
Scholl Concepts Vintage handmade paste wax is a special 50th anniversary exclusive handmade carnauba wax from Scholl Concepts. Scholl Concepts Vintage contain the most expensive and high quality natural raw materials for the very highest demands in regards to paint sealers.
Vintage Wax is a 200ml pure Brazillian Carnauba blend with Cacao that gives long-lasting protection and a class-rivalling finish. This means that Scholl Concepts Premium Vintage Wax has a higher content of natural Grade 1 Brazillian Carnauba wax and increased durability as a result.
As a six star rated protection level handmade wax it leaves a stunning deep gloss finish. The high quality, sealed matt black wax container is packaged in a stylish presentation tin.
- Chocolate scented
- Concours wax
- Machined aluminium pot
Gtechniq C1 Crystal Lacquer + chemically bonds to become the new surface layer of your car/boat/ plane giving unrivalled UV resistance, dirt repellency, easy clean and swirl resistance. Lasts up to 10 times longer than dealer applied products.
C1 Crystal Lacquer + is now supplied with C1.5 Silo Seal, a quartz-based sealant which is ideal for topping up coats of C1 +.
Based on C1 +, C1.5 Silo Seal is very easy to use - spray on, wipe, buff off formulation which can be used as a stand-alone sealant on paintwork, wheels, plastic trim, engine bays, etc. C1.5 is suitable for layering for added gloss and protection.
What's special about Gtechniq C1+ Crystal Lacquer +?
C1 has been independently proven in the world's most respected weathering facility where it proved to offer the best gloss retention of any other product tested. Over a simulated run of 3 years Arizona sunlight a C1+ coated panel lost half the amount of gloss than its next best competitor and 1/3rd less gloss than the average score for all other products tested.
But gloss retention is only part of the story. C1+ offers the following additional benefits:
Extreme Durability: Unlike regular polymer sealants, C1 actually becomes the functional surface of your car's paintwork. It does this by swapping part of its molecular structure with the surface molecules of your car's paintwork. This is a true chemical or covalent bond and as you can imagine this is a much strong bond than a physical bond which is how regular polymers and waxes adhere to your car's paintwork. In tests Gtechniq C1+ outlasted dealer applied sealants by at least 10 times.
Scratch Resistance: Gtechniq C1+ forms a sub micron cyrstalline film which is extremely hard. This characteristic makes c1 extremely effective at preventing minor scratching from poor wash technique on relatively soft automotive paint. We have run tests comparing c1 coated panels with uncoated and against panels coated with various high end carnauba waxes and polymer sealants. On average c1 coated panels exhibited 50% less marring.
Water and dirt repellency: Gtechniq C1+ is a biomimetic coating. It mimics the repellency of plants that repel water and dirt in order to keep their leaves clean. The most commonly cited example in nature is the leaf of the lotus plant
