Dodo Basic of Bling Detailer Spray is my recommendation. Tried it, using it, and fully satisfied and will highly recommend it to everyone.
Dodo Juice Basics of Bling Detailing Spray's water-based formula is compatible with waxes and paint sealants. It can be used during final buffing stages without interfering with fresh wax or sealant (though i won't recommend or ask you to try it on fresh coat of sealent. Let the sealent cure and then apply
Use Dodo Juice Basics of Bling Detailing Spray on paint, glass ( yes i have tried on glass and it does clean them out. I usually use the same microfiber to give a final wipe on the glass without any more sprays) and metals. It leaves a protective coating that will keep future contamination from bonding with the paint. Plus, the paint will bead water like it's freshly waxed
Dodo Juice Basics of Bling Detailing Spray not only looks great, it has a pleasant apple scent. Use it regularly to maintain a just-waxed shine after every wash if you are lazy enough to apply wax.
