3G activation.
Pantech Vega LTE EX (SKY) IM-A820L.
UMTS 2100HSPA 2100LTE 800CDMA 800, 1900
Mobilink 3G is not working. The phone was taken to franchise too, by my friend, but no avail. Any ideas. @vagabondpiper
Specshttp://m.gsmarena.com/pantech_vega_lte_ex_im_a820l-4428.php#
Can any body tell me whats the problem in lg g2 ls980Knock on function m lock to hojata h double tap se per unlock ni hotaIs there any problem or some setting issue?
I have Six NEW USB-lightning cables, out of which I am selling four. (two black, two white)
Aftermarket cables with original apple-supplied hardware - so no device rejection issues that are faced with fake cables.Contact if interested.
Do this dial the following in dialer3845*#980Go in phone settings to find the UPDATE TOUCH FIRMWARE option. Click it and start the test. It will take 10 to 20 seconds to calibrate the touch firmware. During this time DO NOT PANIC as device will literally be unusable. Try it update here with results.
How's Galaxy S6 reviews pls & what's peice of warranty & without warranty
I update touch firmware and now doudle tap wake on working fine...Thnx alotBut code is 5689#*980#
aOa, any body using Xperia Z3 Dual Sim?? How's experience. Need suggestions
Good to know that. Mine works on 3845. Most probably sprint version has some different codes.
Is it on stock firmware or custom one ? Hope baseband is not tempered in ayway ? Is 2G working ?
Any good used phone under 12k.
LG optimus G proIt's a very old phone though, but it's value for money...
1) Big screen2) Quality LCD display3) Powerful specs4) GOOD battery timing
Much better than local Qmobile
Sent from my HTC One using Tapatalk
Self edit.
Moto G and with slight increase in budget you might get Moto X and htc one m7.
G pro is not under 12 k .
Galaxy Core Prime 4G 14000 new, without warranty. Great phone.
Try to extend your range a little and get a moto X, otherwise I agree that the moto g is a good choice
Guys need quick info , any phone within the range of 20k max and does any one have info regarding Vega iron , how is it and is it locked with message length or not ? Any phone new or used are well come. , sent from my Microsoft Lumia 535
I have bought 3 G Pro's for family at 14k (new)
Buying LG G2 D802 is good idea now????
My concern is battery, it is non removable and phone is almost 2 years oldCan be get original battery replacement in Pakistan, as this phone will definite require battery replacement ???
Lg g2, galaxy s3 neo, galaxy s4...best option is lg g2
Sent from my iPhone 6 using PW Forums
