Infinix don't worth it... Trust me, they don't... They're not exactly garbage, per se... But they get pretty close to being one...!
Okay, they provide relatively better and faster SoCs but at the end of the day; you get a heavily "compromised" smartphone...
Good on the hardware fort but lacking in every other category...
I have had an opportunity to try an Infinix at a demo shop at Hafeez Centre, an Infinix Note 2 LTE... It was indeed quite fast, but the build was flimsy, all plastic and creaky, the display was dim and quite pathetic and I'm sure I'd have found more faults if I had spend some considerable time with one...! In which case, the shopkeeper would've gone impatient...!
Anyhow, The same is true about Xiaomi, albeit to a lesser extent in most cases...
And that's where Oppo butts in...
Have you seen The Oppo A37...?
The build quality and the crazy bright IPS Display can actually hold a candle against an iPhone and its signature Retina Display... Its a SOLID well built phone with fantastic cameras, specially when you consider its relatively meager price-tag of around 17 Grands... Okay, 17 Grands for a Quad-Core Smartphone might seem like a LOT, but when you consider the metallic unibody construction, Gorilla Glass 3 protector, quality optics & a quality SoC (A lower mid-range Qualcomm Snapdragon 410, which also happen to grace The Samsung Galaxy J5 (2016) which BTW cost a whooping 26 Grands)...
If you're going to get a Q; get a re-branded Gionee with Amigo UI...
And Infinix...?
Please, don't get a bloody Infinix... They just don't worth it, for the most part...!
