Nice Place To Work....Cool Calm Within Home And 2ndly Great JOB DOne...
I Always Wanted To Do And Even Have Stuff But Unfortunately No Place To Work ..Also Time Is Greater Issue Now
B.t.w WHat Actually Have You Done with Paint Job
I Usually Go Like
Sanding.....Alot Of It....
Filler...Putty....
Sanding....Sanding From 400-600 Grit To 2000
Clean Surface......
Primer.......
Base Coat(Mix Color In Primer Or Matt Finish Of Same Color In Metallic?))
Then Sanding To Smoothen...
1 2 3 Coats Of Metallic Color(Time Duration Between Each Coats?)
Then Clear Lacquer 2-4 Coats (Again Time Duratiin Between Metallic Paint Coat And 1st Lacquer Coat And In Between Each Lacquer Coats)
Then Comes Final Sanding ....Fine Grit Sanding To Smoothen Out .....!!
This is How It Goes I Guess...Mention Duration And Dry Time....!!
Mixing Paint ...Thinning And Making Lacquer Is Also Very Crucial For Nice Clean Job
Also Using Gravity Feed HVLP Gun???? And How Much PSI??? Your Air Compressor Seems Small SO You May Need To Cycle It Again And Again To Get Correct Pressure!
Its Really Fun Painting But Takes Alot Of Effort And Time.....Final Results Surely Worth It.
