Same issue happened to me today. In my case I was pressing accelerator too hard on Kashmir highway and engine light started showing up. Can anyone suggest best mechanic of passo in Rwp/Isb?
I also had the same experience. Please read this and help me. thanks
had to do a scan job for better pointing out the problem
My mechanic was saying that you should get cat convertor cleaned every 10k mileage if using regular fuel and after 30k mileage if using Hi-Octane fuel. Also, after 4, 5 tunings, replace cat convertor. In this way the engine remains healthy and so does the environment (environment wala part is my own opinion ).
10,000 kms is too soon u can only clean it little more than a couple of times depending on the condition.
30,000 kms is fine.
10K clean ups will ruin it.
Good CATs cost PKR 30K and more.
wassalaam
thanks a lot. the mechanic cleaned it with acid... looked like strong acid since the acid was giving smoke when he poured into convertor... Is it ok to clean it with acid?? I heard caustic is better.
issue resolved?
not yet. occasional check engine light (cat convertor bank 1 efficiency below threshold) comes up even after replacing both oxygen sensors.
Get the cat properly cleaned by "motor clean" G8 Islamabad. They are expert in it.
bring it to me on my work shop Totallyautocare tarnol Islamabad03455244481
main ny passo ki tuning karai or phr catalytic converter clearning per uski economy down ho rhi hy or engine light bhi on hy kia karna chahiye
