@Fia and all toyota supporters
well ure SO-CALLED Toyota begins where Chevy ends..i cant stop laughing... if ure so sure that Toyota is better lets compare their products..! Lets talk about SUV's first..
Toyota LandCrusier is the best SUV by toyota..!
Chevrolet Suburban, is the best SUV by Chevrolet..!
LandCrusier:
Land Cruiser's 4.7-liter V8 engine with variable valve timing with intelligence (VVT-i) and an electronic throttle control system with intelligence (ETCS-i) has increased output from 235 horsepower to 275 horsepower. Torque rises by 12 lb.-ft., to 332 lb.-ft., and the 2006 Land Cruiser achieves Low Emissions Vehicle II (LEV II) status.
Suburban:
Vortec 5300 V8 285 hp (213 kW) 00-02 295 hp (220 kW) 03-06 at 5200 rpm and 335 ft·lbf (454 kW) of torque at 4000 rpm).
Vortec 6000 V8 (335 hp at 5200 rpm and 375 ft·lbf of torque at 4000 rpm).
Vortec 8100 V8 (325 hp at 4200 rpm and 447 ft·lbf of torque at 3200 rpm).
Transmission(s) 4-speed automatic
Wheelbase 130 in
Length 222.4 in
Width 79.1 in
Height 76.8 in
Toyota Tundra:
Engine(s)
4.0L V6
4.7L V8
5.7L V8
Transmission(s) 5-speed automatic
6-speed automatic
Wheelbase 126.8 in
145.7 in
164.6 in
Length 209.8 in
228.7 in
246.7 in
Width 79 in
Height 76.4 in
Chevrolet Avalanche
Engine(s) 5.3L V8
5.3L V8
5.3L V8
6.0L V8
Length 221.3 in
Width 79.1 in
Height 76.6 in
Toyota Supra:
---MA70--- 1986.5-1992 3.0 L (2954 cc) 7M-GE I6 200 hp (149 kW) 196 ft·lbf (265 N·m) 5-speed W58 manual
4-speed A340E automatic CAN EUR USA
3.0 L (2954 cc) 7M-GTE turbo I6 230/232 hp (173 kW) 240 ft·lbf (325 N·m) 5-speed R154 manual
4-speed A340E automatic CAN EUR JPN
---MA71--- 1987-1992 3.0 L (2954 cc) 7M-GTE turbo I6 230/232 hp (173 kW) 240 ft·lbf (325 N·m) 5-speed R154 manual
4-speed A340E automatic USA
---GA70--- 1986.5-1992 2.0 L (1988 cc) 1G-GTE turbo I6 185-210 hp (138-157 kW) 173-203 ft·lbf (234-275 N·m) 5-speed W58 manual
4-speed A340E automatic JPN
---JZA70--- 1986.5-1992 2.5 L (2491 cc) 1JZ-GTE Twin Turbo I6 280-300 hp (206-221 kW) 268-272 ft·lbf (363-368 N·m) 5-speed R154 manual
Chevrolet Corvette (mind you its not the specs of Z06 Version):
The powertrain is a new LS2 version of GM's Gen IV aluminum small-block V8 delivering 400 thoroughbred horses harnessed to a choice of a much-improved Tremec 6-speed manual or an upgraded 4-speed automatic with perfection-seeking Performance Algorithm Shifting, which automatically selects the optimal gear for any driving condition. The most powerful standard "small-block" V8 ever offered in a Corvette, the LS2 can launch the '05 to 60 mph in a tick over 4.0 seconds and to a top speed of 186 mph. That simply makes it the fastest production Corvette in history.
Toyota CAmry solara:
2.2 L 5S-FE I4
3.0 L 1MZ-FE V6
Chevrolet Lumina SS:
It has a V8 Engine, 5.7Ltr!
Its 0-100 in 5 seconds!
Transmission is, 5 speed automatic..!
Toyota Estima/Previa:
Production 2006–present (Japan and Australia)
Engine(s) 2.4 L 2AZ-FE I4
3.5 L 2GR-FE V6
Wheelbase 2950 mm
Length 4795 mm
Width 1800 mm
Height 1750 mm
Chevrolet Uplander:
Production 2005–2007
Engine(s) 3.5 L LX9 V6
3.9 L LZ9 V6
3.9 L LGD V6
Wheelbase 113.0 in (SWB)
121.1 in (LWB)
Length 191.0 in (SWB)
204.3 in (LWB)
Width 72.0 in
Height 70.5 in (SWB)
72.0 in (LWB)
Toyota Prado:
Transmission(s) 5-Speed Automatic Overdrive
Wheelbase 2790 mm (109.80 in)
Length 4780 mm (188.20 in)
Width 1860 mm (71.80 in)
Height 1895 mm (74.60 in)
Fuel capacity 23 gal.
Chevrolet Trailblazer:
Engine(s) 4.2 L LL8 I6
5.3 L LM4 V8 (EXT)
5.3 L LH6 V8
Wheelbase SWB: 113.0 in
EXT: 129.0 in
Length SWB: 191.8 in
EXT: 207.8 in
Width SWB: 74.7 in (2006-present)
74.5 in (2002-05)
EXT: 75.5 in (2006)
77.1 in (2002-05)
Height SWB: 72.5 in (2006-present)
LWB: 74.5 in (2002-05)
Lets talk about the sports version of both the SUVs cause some people here are talking abt Lexus GX470..! check the specs of both of em!!!
Lexus GX470:
The Lexus GX 470 is powered by a 4.7 L, 32-valve, four-cam V8 engine with 270 hp (201 kW) at 5,400 rpm and 330 ft·lbf (447 N·m) of torque at 3,400 rpm.
Chevrolet Trailblazer SS:
This new TrailBlazer comes standard with a 6.0 L LS2 V8 based off the same engine that comes standard in the Chevrolet Corvette. The LS2 is rated at 395 hp with 400 ft·lbf of torque and can accelerate from 0 to 60 mph in an estimated 5.8 seconds with quarter mile times around 13.5 seconds at 100.0 mph. Other differences entail the use of a heavy-duty 4-speed automatic transmission, a cold air intake package, a 4.10 ratio limited slip rear differential, a ZQ8 sport suspension, specially designed front brakes with brake pads similar to those found on the Corvette, and optional all-wheel drive (via a Torsen T-3 center differential). Along with these performance upgrades, the SS received many minor exterior changes including a redesigned front and rear bumper, color-matched grille, factory installed 20 inch wheels, and the absence of a roof rack. Inside the SS is an exclusive black cloth or leather interior with SS specific embroidery on the seats. A DVD navigation system and XM Satellite Radio are also available on the SS model. As with most GM vehicles, OnStar is standard with a free one year subscription included.
Toyota Avalon:
Engine(s) 3.5 L 2GR-FE V6
Transmission(s) 5-speed U151E automatic
Wheelbase 111.1 in
Length 197.2 in
Width 72.8 in
Height 58.5 in
Fuel capacity 18.5 US gal
Chevrolet Caprice/ Holden Statesman
Statesman International, and the Caprice. Engines were a 3.8 L Ecotec unit (based on a Buick design), a supercharged version of the same, and the 5.7 L LS1 V8. The doors (and front windscreen) were again shared with the lesser Commodore/ Chevrolet Lumina..!
