Cool how did u do it?
what mods do you have ? and how much mileage have u gained?
https://www.pakwheels.com/forums/performance-modification-tune-up-preventive-maintenance/160408-cultus-efi-performance-upgrade
58K on the clock. i can post pics of DIY on moday cuz goin out now for weekend
Its a choke cable, a butterfly in intake pipe, when i push the choke (Close position) the butterfly opens fully for maximum intake, while when i switch to cng, i gently pull the choke cable and adjust where cng starts to perform well.
im always here to help fellow members n share knowledge which i have:) ,thank u for the appreciation,leme just delete all off topic replies
tuning is one of the things,bad plugs,clogged fuel filters can be more resons as well
Performance on petrol used to be great but since the last few months when i convert it to petrol it starts knocking and doesnt run for a long period. I think there is something wrong with my fuel pump.
knocking can be due to1. poor fuel( if u dont use hioctane)2. too much advanced timings for cng
As i expalined earlier try to get rid of CNG Venturi instead go for Jet in the stock box for cng.Get the Valve clearance (tappet setiting) from some good mechanic.FOr KHi visit The Tweak Shop owner by PW member Asad moak89 or tariq both are good tunners.They usualy tune performance cars.
hassan rashid u may go fuel injection checkup the knocking also occur due to this problem ... USE STP Fuel injection cleaner..
Will do bro thankyou very much
if u feel some vibration in idle state at its optimum temperature then u must also go for throttle cleaning..
Btw guys one more thing! Will the intake work on CNG? Anyone currently driving with intake on cng?
it will iv even installed intake on frnds cng auto coure and it ran all well
Without any butterfly ( blocker, something like that ) ? And what type of intake was it?
yes it will work on cng,u jus need to retune the idling on gas,tats it
