Painter has asked me to pay 5000 extra if I want the car to be painted in a paint booth. I will see his paint booth today and then decide
Thank you for the contact details. I'll contact him tomorrow
Further, please do update here regarding the paint job.
I also need to get my civic painted. it is in pretty bad shape
Been looking for a denter painter for quite some time
Update:The paint booth does not looks like some very high tech imported unit but it has the. Heater Blowers and suction motorsLooks promising to me as I believe if the painter applies branded paint sikkens and clear coat. Etc and paints it in a booth the chances of a better finish are high.
Mostly temp guage does have issuesWhat I have read is the wire need to directly soldered to the board.Else I think it will easily fit in your carI have seen videos on YouTube.
Please update here if you got it swapped
Please advise which headlights are better Depo brand new Headlights Or Japanese Genuine Honda Stanley headlamps from a kabuli half cut
Japanese definitely, but check them thoroughly for damage and repairs. Don't forget to get fresh rubber sealing boots for the bulb entry points.
Noted Sir. Thankyou for the prompt response.
I am getting my car painted. will share pictures InShaaAllah.I have bought Nexa automotive paint Yr505 MAnd Nexa clearcoat,Nexa hardner and Nexa thinner
Depo New Would be better you hardly find never open Kabli headlight also age really matter in Plastic although its Japanese.As you got new paint job Japanese look faded as compare to new.these are Depo Headlight
As per my observation mostly these aftermarket headlights have poor light focusing ability due to imperfections in the reflector bowl as compared to the oem. Can't say much about the Depo ones if they have comparable output as the oem ones.
Standard 55/60 watts tubes produce ample light output due to correct focusing in the oem headlights.
Shabbir bhai how are you
G bhai I am good, what about you? Kindly introduce yourself to this community with your car details.
The lights available in junkyard should not be bought.
Reason being is they are repaired most of the times.Second even if not repaired they have been buffed out for shine which removes the UV protective coating leading to yellowness within a few months of use.
Buy Depo lights they are as good as Genuine.
Any update regarding the paint job?
Hello guys,
need to buy new bumpers and fenders for my civic 2000
Now, there are two different types available
Malaysian and taiwan made
Which one should I go for?
What do you guys suggest?
Buy from Bilal gunj. They will be better than all malysian stuff
Did you swap the engine ? If yes, which one, and for how much. Thanks.
I am in Islamabad
Chah sultan in pindi
I know the place to buy. I can't go for kabli parts (too expensive)
I just want to know what is the difference between Taiwanese and Malaysian and which one is better
