If you can provide us with the engine code, and ecu code, you may get help here. @samson.naz
Engine code can be found in the front of the engine, under the upper radiator hose. Ecu can be found on the passenger side kick panel. You need to remove the black plastic. There will be a sticker on the ecu. Take pic of that.
