If connector is behaving erratically then better change it as I decribed earlier.
Bulb is not recommended, installing an LED in series with a resistor can be a better option. However, I will advise you to add an extra coolant temperature sensor with digital readout. And if you can get one with a watchdog to generate alarm on user selectable temperature can be a cherry on the cake.
