If you are going for oem type restoration then go for the rear ferio bumper
otherwise try to get oem bumpers just like you went for oem headlights - you get the best fitment no matter what part you go for
For that reason i'll suggest you to go for oem VTi rims of the same model and then add lowering springs at max - no need for coils
Otherwise any good set of branded wheels would be enough , 16" would be the max and if you are adding lowerings then 205 width with aspect ratio of 50 would be the top limit
And yes try to find oem HONDA front mesh grill from Bilal gunj - you can get an oem lip for this model too , I saw quite a few front bumpers of this shape with very clean lips
Oem air press would also look good
The thing is that dont rush to buy cheap stuff all of a sudden , it doesn't matter if you end up without adding all the things you wished for , slow and steady wins the race , add good quality stuff gradually instead of going for replicas that wont last long
