I advise you to change your mechanic first of all.
Clutch bearing sound relates in first step when you release the clutch padal but as you also mentioning that this sound comes at high speed also then be sure your bearing is not acting upon at high speed of your car.
Clutch bearing start working whenever you press the padal only.
I am pretty sure your gear box is already repaired/opened.
