read the codes from the check light flash sequence after shorting the diag pins, for shifting problem - your transmission is hydraulic it has a kickdown cable that sets shift timing and also aggression of the shift. So if your engine is in bad tune you need to first rectify the problem of acceleration then adjust the kickdown cable.
