Compressed Natural Gas (CNG) is a substitute for gasoline (petrol), diesel, or propane fuel. It is considered to be a more environmentally "clean" alternative to those fuels and it is much safer than other motor fuels in the event of a fuel spill: natural gas is lighter than air, so it disperses quickly when leaked or spilled.
It is made by compressing natural gas (which is mainly composed of methane (CH4)),to less than 1% of its volume at standard atmospheric pressure. It is stored and distributed in hard containers, at a normal pressure of 200β220 bar (20β22 MPa), usually in cylindrical or spherical shapes .
In response to high fuel prices and environmental concerns, compressed natural gas is starting to be used in light-duty passenger vehicles and pickup trucks, medium-duty delivery trucks, and in transit and school buses.
Technology
CNG can be used in Otto-cycle (gasoline) and modified Diesel cycle engines. Lean-burn Otto-cycle engines can achieve higher thermal efficiencies when compared with stoichiometric Otto-cycle engines at the expense of higher NOx and hydrocarbon emissions. Electronically-controlled stoichiometric engines offer the lowest emissions across the board and the highest possible power output, especially when combined with EGR, turbocharging and intercooling, and three-way catalytic converters, but suffer in terms of heat rejection and fuel consumption. A suitably designed natural gas engine may have a higher output compared with a petrol engine because the octane number of natural gas is higher than that of petrol.
CNG may be refueled from low-pressure ("slow-fill") or high-pressure ("fast-fill") systems. The difference lies in the cost of the station vs. the refueling time. There are also some implementations to refuel out of a residential gas line during the night, but this is forbidden in some countries.
CNG cylinders can be made of steel, aluminum, or plastic. Lightweight composite (fibre-wrapped plastic) cylinders are especially beneficial for vehicular use because they offer significant weight reductions when compared with earlier generation steel and aluminum cylinders, which leads to lower fuel consumption. The CNG cylinders generally follow the ISO 11439 standard. [1]
The equipment required for CNG to be delivered to an Otto-cycle engine includes a pressure regulator (a device that converts the natural gas from storage pressure to metering pressure) and a gas mixer or gas injectors (fuel metering devices). Earlier-generation CNG conversion kits featured venturi-type gas mixers that metered fuel using the Venturi effect. Often assisting the gas mixer was a metering valve actuated by a stepper motor relying on feedback from an exhaust gas oxygen sensor. Newer CNG conversion kits feature electronic multi-point gas injection, similar to petrol injection systems found in most of today's cars.
Drawbacks
Compressed natural gas vehicles require a greater amount of space for fuel storage than conventional gasoline power vehicles. Since it is a compressed gas, rather than a liquid like gasoline, CNG takes up more space for each GGE (Gallon of Gas Equivalent). Therefore, the tanks used to store the CNG usually take up additional space in the trunk of a car or bed of a pickup truck which runs on CNG. While CNG-powered vehicles are considered to be safer than gasoline-powered vehicles [2][3], there are concerns about how best to fight fires involving CNG vehicles.[4]
CNG compared to LPG
CNG is often confused with liquefied Petroleum gas (LNG). While both are stored forms of natural gas, the key difference is that CNG is in compressed form, while LPG is in liquefied form. CNG has a lower cost of production and storage compared to LPG as it does not require an expensive cooling process and cryogenic tanks. CNG requires a much larger volume to store the same mass of gasoline or petrol and the use of very high pressures (3000 to 4000 psi, or 205 to 275 bar).
Worldwide
Canada
Canada is a large producer of natural gas, so it follows that CNG is used in Canada as an economical motor fuel. Canadian industry has developed CNG-fueled truck and bus engines, CNG-fueled transit buses, and light trucks and taxis. Both CNG and propane refueling stations are not difficult to find in major centres.
United States of America
In the US, use of CNG varies from state to state. In California, CNG is used extensively in local city and county fleets, as well as public transportation (city/school busses). Personal use of CNG is a small niche market currently, though with current incentives available, it is experiencing unprecedented growth. The state of Utah offers a subsidised statewide network of CNG filling stations at a rate of $0.64/gge[5], while gasoline is above $4.00/gal. Elsewhere in the nation, retail prices average around $2.50/gge, with home refueling units compressing gas from residential gas lines for approx $1.50/gge. Other than aftermarket conversions, and government used vehicle auctions, the only currently produced CNG vehicle in the US is the Honda Civic GX sedan, which is made in limited numbers and available only in a few states.
Europe
In Italy there is the largest number of CNGV in Europe. The use of Methane for vehicles was started during the 30' years during the embargo against the Fascism and was continued with alternate phase to today. Actually (06/2008) there is a large expansion of market of Gas vehicles (CNG and LPG) caused by the raise of Petrol price and by the anti pollution normative. Before the 1995 the CNG conversion was realized with an After Market kit, some large producer was Landi Renzo (quoted at Milan stock exchange BorsaItalia), Tartarini Auto, OMVL, BiGAs,... and AeB for electronic part used by the most part of kit producer. Landi Renzo and Tartarini have a sell Division in Asia and South America.
After 1995 bi-fuel vehicles was build in factory from various Car Fiat,Opel(GM),Volkswagen,Citroen,Renault,Volvo and Mercedes sell various model of car and small truck CNG powered. Usually the part used from a car producer was build from a producer of a After Market Kit, i.e. Fiat use Tartarini Auto part, Volkswagen use Landi Renzo.
In Germany, CNG-generated vehicles are expected to increase to two million units of motor-transport by the year 2020. The cost for CNG fuel is between 1/3 and 1/2 compared to other fossil fuels in Europe.[citation needed]
South America
Argentina and Brazil are the two countries with the largest fleets of CNG vehicles. Conversion has been facilitated by a substantial price differential with liquid fuels, locally-produced conversion equipment and a growing CNG-delivery infrastructure. A 'Blue-network' of CNG stations is being developed on the major highways of the Southern Cone (including Chile and Bolivia) to allow for long-haul transportation fuelled by CNG.
Asia
CNG costs are at Rupees 18.90(USD $0.46) per kg compared with Rs.56.00 (US$ 1.45) per liter of petrol. The cost saving is immense along with reduced emissions and environmentally friendlier cars.
CNG has grown into one of the major fuel sources used in car engines in Iran, Pakistan, Bangladesh and India. The use of CNG is mandated for the public transport system of India's capital New Delhi as well as for the city of Ahmedabad in the state of Gujarat. The Delhi Transport Corporation operates the world's largest fleet of CNG buses. The government of Punjab, Pakistan, the most populous province of that country, has mandated that all public-transport vehicles will use CNG by 2007. Today many rickshaws as well as personal vehicles in India and Bangladesh are being converted to CNG powered technology, the cost of which is in the range of $800-$1000. In the Bangladesh capital of Dhaka not a single auto rickshaw without CNG has been permitted since 2003. As of July 2007 Pakistan is the largest user of CNG in Asia, and second largest user in the world.[6]
According to the International Association for Natural Gas Vehicles, Pakistan has the second-largest number of natural gas vehicles.[6] In the Middle East and Africa, Egypt is a top ten country in the world with more than 63000 CNG vehicles and 95 fueling stations nationwide. Egypt was also the first nation in Africa and the Middle East to open a public CNG fueling station in January 1996.[7]
In Singapore CNG is increasingly being used by public transport vehicles like buses and taxis, as well as goods vehicles. However, according to Channel NewsAsia on April 18, 2008, more owners of private cars in this country are converting their petrol-driven vehicles to also run on CNG - motivated no doubt by fiercely-escalating petrol prices these days.
The initial cost of converting a regular car to bi-fuel at the German conversion workshop of C. Melchers-Galileo, for example, is around S$4,000 (US$2,300); with the promise of real cost-savings bi-fuel cars bring in the long term.
Singapore currently has three operating filling stations for natural gas. SembCorp Gas Pte Ltd runs the station on Jurong Island, and jointly with Singapore Petroleum Company, the filling station at Jalan Buroh. Both these stations are in the western part of the country. Another station on the mainland is in Mandai Link to the north and is operated by SMART Energy. SMART also plans a second station on Serangoon North Ave 5 which will be set up the 2nd half of 2008; so will two more - at Jalan Bukit Merah and Bedok in the central and eastern parts of the country.
As a key incentive for using this eco-friendly fuel Singapore has a Green Vehicle Rebate (GVR) for users of CNG technology. First introduced in January 2001, the GVR grants a 40% discount on the Open Market Value (OMV) cost of newly-registered green passenger vehicles.
Oceania
During the 1970s and 1980s, CNG was commonly used in New Zealand in the wake of the oil crises, but fell into decline after petrol prices receded.
Brisbane Transport and Transperth in Australia have both adopted a policy of only purchasing CNG buses in future. Transperth is purchasing 451 Mercedes-Benz OC500LE buses and is undertaking trials with articulated CNG buses from Scania, MAN, and Irisbus, while Brisbane Transport has purchased 216 Scania L94UB and 240 MAN 18.310 models as well as 30 MAN NG 313 articulated CNG buses. The State Transit Authority of New South Wales (operating under the name "Sydney Buses") operates 102 Scania L113CRB buses, two Mercedes-Benz O405 buses and 300 Mercedes-Benz O405NH buses and are now taking delivery of 255 Euro 5-compliant Mercedes-Benz OC500LEs.
In the 1990s Benders Buslines of Geelong, Victoria trialled CNG buses for the Energy Research and Development Corporation.[8] Recently Landi Renzo of Italy has set up a production subsidiary in Karachi to cater to the growing demand of CNG Kits in Pakistan.OEM's like Toyota Pakistan and Suzuki Pakistan is producing company fitted CNG cars.
Martin Ferguson, Ollie Clark, and Noel Childs featured on ABC 7.30 Report raising the issue of CNG as an overlooked transport fuel option in Australia, highlighting the large volumes of LNG currently being exported from the North West Shelf in light of the cost of importing crude oil to Australia. The opportunity and pathways to industry development are mapped out in summary on the Rosetta Moon
