Dear fyq;
I have recently bought Corona 88, with 1600cc, carburetor engine. CNG is installed. On a Cylinder of 55 it gives me around 130-140 with and without AC. I usually let the CNG get completely consumed and run on Petrol before refilling. By doing this I am facing a problem, whenever I refill CNG and convert back from petrol, it works fine at that time. But after sometime the solenoid valve (I hope the part name is correct) on CNG Kit leaks making engine stall. I shutdown the valve by turning CNG off from CNG switch. Then after couple of seconds, when I turn the CNG switch on it works fine. I have gone to couple of CNG mechanics and they failed to explain this. Please note that this does not happened if I refill CNG without converting to Petrol.
I hope I am able to communicate you my problem.
Thanks and Best Regards
JA
