now this is excerpt from landi renzo site describing this device
LAMBDA CONTROL SYSTEM LC01
It's an electronic system which manages the carburation in traditional gas system (LPG or natural gas) with mixer for vehicles equipped with a lambda sensor. The LC01 ECU ensures correct air/fuel mixture by driving the actuator which doses the gas flow from the regulator to the mixer, located on the intake manifold (gas flow continuous regulation system). LCS-LC01 system does not need manual adjustments and it can automatically adapt to the different environmental conditions and use of the vehicles.
The system consists of the following components:
1. COMPUTER LCS-LC01
The LCS-LC01 computer is defined as a Stand Alone system for the fact it doesnt interact directly with the petrol system ECU, but it works in a separate and independent way. The computer processes the signals from the lambda sensor, the ignition input, throttle body angle signal to manage the correct air/fuel mixture on each engine working condition, by driving the actuator which doses the gas flow at the engine entry.
The main functions of the LC01 computer are:
Emulation of the correct signal of lambda sensor
A diagnostic and programming system by means of a special Tester-Programme to control mixture and conversion optimization
Petrol starting with automatic switch over to gas in a period of time depending on the environmental and engine conditions by managing the gas solenoid valve
Actuator driving to adjust the mixture
Managing of different safety devices when the vehicle runs on gas, as for instance a built-in system to cut off petrol injection and an electronic safety device that cuts off supply to the LPG/natural gas solenoid valves if the engine talls.
2. ACTUATOR
Electromechanical device which doses the gas capacity by turning a step motor controlled by the computer so as to maintain the correct air/fuel mixture on each engine working condition. 3. LCS-LC01 SWITCH/GAUGE
Electronic component, located inside the interior compartment, whose main functions are:
Gas/petrol selection with 2 positions and gauge for the fuel being used by means of 2 lighting led
Display of the level of gas in the tank by means of 5 led
Diagnosis device
Acoustic indicator (buzzer) - optional.
