the idea of blocking the intake is completly rong, i tried and it dosent word. this isnt the way to block intake,
if u have blockd and then press of pedal, at first less air will flow but when u reach higher rpms like 3000+
the air flow will be same as when it was not bllocked.
only difference is that ur engine is trying ahrd to get that amount of air.
blocked intake:
engine takes more time to reach that rpm
unblockd, it will reach faster
but when both (blocked and unclocked0 reached say 4000
air flow will be the same.
one more thing as engine is desperate to get air, and not easly getting it, engine will suck more gas then normal.
ur problem can be adjusted by the idle knob!
i had same problem but now its great!
ENGINE NEEDS AIR TO RUN. otherwise blockage has bad effects on engine life NVR DO IT!!!
cng may require less air to burn, excess air simply wents out from exhaust.
however if there is too less gas then u may need to increase a bit. but still dont block intake
if blocking was a nice way why landi etc make such a piece of equipement to block a bit of intake
