GOOD LUCK
hello!yaar air filter and plugs plays important role in avg and performance.....check air filter that if need change so change it....check plugs if required so set its distance to 0.6mm..(default comes with 0.8mm distance).....if u have advancer so don't need to change distance.....and yes friends CNG near baloch are good....there is a person named "Arshad Bhai" having french cut so he's the main person....ask about him all others are not so good as it was....but i tell u one thing that they are good for ones having their hand installed CNG kits.....if u go so they tell u 100 faults in installer and Kit....it happened with me as i am telling u..... the best kit is of itilain manufacturer Lendi-Renzo...any ways check these and post reply....Thanxxx
I took my car to the mechanic. Now the engine doesn't stop when I press clutch. Don't know about the car missing thing now ,will drive it for a couple of days more to check.He did that RPM setting. Now the engine remains at 1 RPM on petrol and at 0.5 - 1 on CNG.He also replaced two plugs i.e. he pulled them out and swapped. We also do this to some electronic items like clock, TV remote when the cells are weak. What we do is that we just replace the cells with each other to give a new life to that electronic item.I think he did the same by replacing plugs.
hello!maybe due to lean mixture plugs are fouling so he cleaned and set the gap and install it as i say.........to adjust gaps....check it atleast 2 weeks then known the performance ..it may also increase ur avg....Thanxxx
sali, How much TAP and 4 Bosch plugs will cost?
kkool you live in Karachi?
hi Tech Manit was nice to know that ur car has been diagnosed.........the plugs should cost not more than 1500 rs coz i bought two pairs from Honda Authorized Dealers in Rawalpindi....(but they dont have em now)....as i frequently ask them for a set....and by the Way i Live in Islamabad.........
Dont Change Your ECU Just Like That
That CNG noise problem is solved.New regulator has been fitted.
hello!yaar here in karachi i don't actually know but my idea is that it will cost u around 2100-2500(Bosch +4) and TAP for Efi comes with kits.....if u don't have or got damaged so ask the conversion centre they should tell u the real price...Thanxxx
I have an Alto VXR CNG. Car has been riddled with problems from the start, but recently is has found a new way to aggravate me. It stops running on CNG, even though there is CNG in the tank, and will only run on petrol. I got it fixed from suzuki dealer, and a day later it won't even run on petrol anymore. It's not even starting now. Any ideas what to do and where is the best place to get it fixed? HELP!
@All............kkoool......
How many cng experts we have cultivated in few days.....lolzzzzzzzzz, if the groth rate will remain the same, we will have less cars, less cng station but more expertzzzz......
Good Show, wellcome to Pakistan......
@matrixGo to Jilani Cng or Friends cng ( Karachi )
btw, u missed LOGAS when he was in khi
Thanks buddy.
