if you guys think the suzuki G10 is good, then you need to see the Subaru version of this engine, it was installed in the J-10, Justys, Domingo vans.
That engine has a very very heavy iron block, Weighs a lot more than a daihatsu CB block, forged crank, forged rods, forged pistons with alphin carrier ring lands, counterbalancer shaft and the entire rotating assembly was balanced as one.
In proper nick that engine will survive a few world wars, it refuses to die when run properly, the reason it failed in Pakistan was because our people want to use tap water in the cooling systems - its waterpump was shared with the oil pump and rusting/erosion lead to mixing - its oil pump/water pump assembly was very expensive to buy because of its design. If used with correct coolant - its an insanely long life part.
back to regular broadcast.
the first suzuki cultus offered by PS was the best in build quality (the one with no rpm meter), it also had a lot more small parts like wiring clips/finishing items on it and looked more like a proper car as compared to the made in lalukhet cultus that PS sell now.
