i used a speaker to locate the output. and all the following 5 points of the soldered jack input gave me the output. i am attaching the following pics, kindly let me whts the purpose of the points marked with "?(1)" and "?(2)". can these two points b used for the output? as the other three r clearly meant for the input via 2.5mm jack.
secondly, i joined the common grounds of the aux cables in the following manner. the middle wire constitutes the common ground. kindly let me if this is rightly done. Also, plz tell me where to solder these wires on the PCB in the first pic above?
