there is a disturbing sound while driving like krrrr krrr very light sound
Don't change intake manifold i tried but sound was still there
Check the cylencer
I faced the same issue back in 2017. The car is altis 1.6 2012 model. I tried many mechanics but no one could identify/diagnose the issue. I drove the car for an year, its not a serious issue just annoying krr krr and ratlling sound between 1 and 2 rpm, on higher rpms the sound vanishes. The culprit is the chain set inside the engine (Picture attached). My mechanic changed the tensioner/adjuster, chain and the chain-gears. (according to mechanic he used the parts from Prius engine). The rattling sound went away and it has been more than 1 year the car is fine. Total cost was 15k. (10k for parts, 5k mazdori).
dear ImranI have the same problem, kindly share the address and contact number of the mechanic. thanks
Can you please share the number of the person who provided you these parts?
Dawlat ustaad +923447448056+923119168773
No need to open the engine just side of chain and replaced. This is common problem in gli 2012. Mechanic will charge 1000 to 1500 and tentioner will be in range of 2500to 4500
Please refer Any machenic in Karachi who can help me out professionally as I am facing the same issue in2013 Altis.
Salam was it problem solved?
