Does complete ac service cover that, secondly this dust issue etc i have heard is only happens if you use ac with fresh air, if you keep cabin air recirculating it does not happen....(A)
You mean full ac service from toyota? It should, but they have some weird protocols sometimes do can't say for sure
Cabin has carpets and **** on the mats any given time
Sent from my Samsung 796cc via some chain reactions..
Let me rephrase. Tripping is not happening at the right time causing ice build up which restricts air flow. Cannot be the blower itself.
Untrue. Dust comes in even without using fresh air. mostly from mats and u open wndow once or twice at least at the time of paying toll or something similiar. Using fresh air vent clogs the core earlier for sure but that does not mean that only cabin dust cannot clog it.
How to diagnose this problem and what is the solution? Btw sent the car to garden motors for check up, they checked everything and ruled that there is nothing wrong with the Ac or anything else. I guess they will not be able to diagnose anything unless something big happens.
Need a thermometer toc heck at what temperature it is tripping Preferably this should be checked while moving in same circumstances where you feel reduced air flow. Is the system correctly charged with gas? Overcharging possibility?
i've been to toyota ravi and garden only till date and both of them have goofs as trained technicians apart from from maybe one or two guys
Nothing like overcharging. No ac work has been done ever till now.
Same circumstances are hard to replicate as it occured after 5 hrs of driving on motorway and normal roads....
se saloon ws discontinued in july 2005,how come you had a 2006
Altis came in march may 2006 and se saloon was sold till march 2006 so technically it is 2006
Make it in 2006
no way altis was in showrooms for sale as of july 2005 and I myself had a 2005 altis
Sorry but low gas can cause this. Witchcraft but I was wrong earlier get gaa charged after leak test. Should be fine. Your issue is core icing.
Sent from my HUAWEI G610-U20 using PW Forums mobile app
Everything was checked today had gas been less wouldn't have they noticed? Core icing would be solved by maintaining optimum gas level?
Professor sahab i shared the probable causes in my own opinion. Cannot comment on what was chaecked and what should have been checked because i was not the man on ground.
If you feel that AC is working fine for now then better to check in same situations on a long run. Diagnosing such remote occurances wont be easy.
@syncview
try toyota walton motorsmuch better
@xulfiqar
Well said! Sorry its an old reply, but I am coming up to my 40K on 8 gen civic, and wondering what must be changed? does the automatic gear box fluid needs to be changed? I a e60 530D BMW I had a couple of years, I was informed the gear box is sealed for life and fluid does not need to be changed for life!! how come hondas want to change it so often? A money making scheme or real need?
Add a cabin filter there in the empty slot
