aoa
just read about your problem
i have vxri 2009 model
in last summer i suffered same issue
they just reset your ecu by laptop which u can reset every time by unplug your battery terminals
check your Radiator Fan is it on automatic mode as sometimes direct fan causes fluctuation in Rpms.
also due to dust and hot environment the lambda isnt much successfull in pakistan so just remove it and go on option of 4.5k charges and spark plug cables change
and never try to simply remove lambda with manual T as your MAF sensor will cause error and chk engine light will make things worst
so Go to an expert car ecu/electrician mechanic
as local mechanics arent good they creat mesh of wires and install seprate emulator too for extra charges but good electricians used car's original emulator which is built in in ecu of cultus
then do the cng kit and cylinder service too
after all these you will surly get 200km plus on non ac and 170km on ac in city on low rpms
i am not a technical person but i learned it by experience and experiments too
you can share your experience too i will polish my knowledge too
