Change the plug wires if you haven't yet. The major symptoms of weak wires are jerks on steady acceleration, loss of acceleration and engine takes time to start. Get the injectors cleaned. Dirty injectors can cause troubles. Take your car to a good electrician and ask him to check its wiring. If after doing everything, you are still not able to achieve the desired results, admit it then that your car engine has gone weak.
