yes you are right , i also think same ,,,,,,,,,,,,,but need some expert suggestion,,,,,,,,,,,,,,,,,you see in mehran ,,,,,,,,,,,,,,,,its imposible in mehran ,,,,,,,,,,,,because it comes with mechanical fuel pump which is connected with distributer,,,,,,,,,,,,,,,this pump cant be stoped in any way,,,,,,,,,,,,,,,,,,,,,and the return fuel pipe passes through the carburator,,,,,,,,,,,,,,means when we run it on CNG the fuel pump outlet is totally blocked,,,,,,,,,,,,,,,,no way the fuel pump can be stoped,,,,,,,,,,,,,,,and no way that the fuel can be passed through the return pipe,,,,,,,,,,,,,,,,,,,,,,,in this case you have heared from many mehran oweners that there fuel pump goes out of order when they wont run the engine on petrol
serious debate needed to save the fuel pump ,,,,,,,,,,,,,
i guess the option of connecting the fuel pump 12 V supply to the solenoid valve is batter option,,,,,,,,,,,,,,,,,but may be we need to add a relay in this cirucit and connect the pump direct to the battery becuase there is no enough amp on that solenoid valve wire,,,,,,,,,,,,,,,the fuel pump wire passes through the fuse box near acclerator cable and it can be easily altered from there ,,,,,,,,,,,,,
