well this thing was in my mind ,,,,,,,,,,,,,came thru this problem many years before in FX and mehran,,,,,,,,,,as you know both have similar engine , but the AC system are different,,,,,,,,,many of you may have forgotten these 2 cars fx and mehran but i still remember the ac experence on these 2 cars,,,,,,,,,,,,,,fx comes with sanden rotary compressor and mehran comes with ND piston compressor ( the same as the one i have grounded and the only difference is with the refregrant) , both the cars have poor AC system as you also have experences or listen ,,,,,,,,,,,,FX has the same problem as you mention,,,,,,,,,,,,,and mehran has high head pressure problem,,,,,,,,,,,mean it wont work once the car cross 100 Km/h ,,,,,,,,,,,,,i fix both of them with a very simple fix ,,,,,,,,,,,,,,you may have noticed the crank shaft pully which runs alternator and compressor ,,,,,,,,,,,,,in FX the originally pully which drive the ac belt is of very small dia,,,,,,,,and in mehran its large , and even larger than that which runs alternator,,,,,,,,,,,i instal a bigger pully in FX and grounded the original one,,,,,,,,,the pully was originally of japan assamble mehran 800cc ,,,,,,,,,ac works fine on low RPM and cooling was all good and obviously it puts load on engine but that was bareable because at that time there is nothing name CNG ,,,,,,,,,,,,later after some time i experenced mehran,,,,,,,,,,,and found that its ac cooling goes off as car crosses 100Km ,,,,,,,,,,at first i though the comp trips off ,,,,,,,,,,,so i by pass every thing but still nothing happens,,,,,,,,,,,,,later found that its because of high head pressure which ND piston compressor creates ,,,,,,,,,also it was fitted with old style condenser the same as fitted right now in my 06 cultus ,,,,,,,,,any how i pull back that pully from my junk yard and instal it in mehran,,,,,,,,,,,problem solved and ac cooling is all ok even at 130km ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,\
i have check the pressure of the compressor which i have installed in 06 cultus ,,,,,,,,,,,,,some how it has that inherated problem but i guess it will work ,,,,,,,,,,,,cooling will be reduces on low rpm but not as much , and second thing is that mostelly car runs on higher RPM above 2K ,,,,,,,i guess it will creat not much problem,,,,,,,,,,,,,,,
