i have just check the balleno condencer ,,,,,,,,,,,,i have found that it can be easily fitted in cultus ,,,,,,,,,,infect cultus has option for installing bigger conderncer,,,,,,,,,,,,,,,,as you know condencer fits with just 2 bolts at the upper side and 2 hooks which goes into the cultus frount foundation ,,,,,,,,,,,,,there are space and holes left for bolts and hooks ,,,,,,,,,,,,so it can be easily fitted,,,,,,,,,,,,,,
but 2 things are in my mind,,,,,,,,,,,,first is that the original condernce wont full cover the radiator,,,,,,,,,but this balleno condencer which is longer in length can fully cover the radiator, just like in mehran,,,,,,,,,,which will block the radiator air flow and also the condencer hot air will directelly flow thow radiator ,,,,,,,which can result in engine overheating,,,,,,,,,if its so then we can do 2 things,,,,,,,,,,either instal 2 fans on condencer or make a system so that the radiator fans kicks in when we switch on the,,,,,,,,,,,,check the pic,,,,,,,,,
second this about the fan,,,,,,,,,,,,you can see the balleno conderncer in pic ,,,,,,i take that pic from web but its same as the one availabe in market,......can you tell me is that high cubic feet per minute fan or same as the old style 4 curved shape blade ............
