set the knob to 20v range, and put both probes into the plug/coupler/grip/whateveryouwanttocall it
then check battery voltage, if there is a major difference, something is wrong, else you are good.
It can even be a faulty alternator, if the battery voltage is below 14v . at idle with headlights on, the voltage should be 14+.
