I just replaced my PCV valve with a brand new one and genuine part for 600 rupees, however there is always 20 to 30 ml of oil in my air filter cleaner box when I open it up every month. It is pesky and how to get rid of this problem. Car is carby cultus 2001 which has a stong engine and doesn't reduce oil.
I had the same problem with my cultus 2000 changed PCV twice but again same problem when travelling on long at continous speed of 90km engine oil gets into airfilter. One mechanic told me that you have to change tappet cover bcz it has seals where pipe gous out to filter and pcv valve and seals are demaged. Experts that would also be the reason for that? Or any recomendation to get rid of this situation?
waseem bhai hope u enjoying good health start with economic solutions.make sure no leakage of engine oil. If found any, change the respective seal/pipe.keep air filter clean.Remove air blockage as long as cng is not available.
W salam naveed bhai m fine thanks. Sir g chked already ur suggested point all is well cng blockage already removed set and tuned on petrol.
bahi ap ny ye masla kaysy hall kiya tha mari cultus ky air filter box main be ganda sa oil hota hy. mechanic ny foam rakha hy par wo be oil sy bhar jata hy. Kiya pcv valve change karny sy masla hall ho jay ga? Ap ka problem kaysy solve huwa tha. Or ye pcv volve mily ga kidher sy. Plz reply. Agr ho saky to koi mujy text message kar day koi bee. Thanks 03335245386 imrancultus 04 model. carby
Dear imranwah,Agar air filtter mein thora sa oil aata he to phir aap PCV valve change karein aur agar zyada he to phir head utarna pare ga kion k head aur block k beech mein block k ooper ek brass (peetal) ka oil vent valve hota he jo oil pump se aane wale oil ke pressure ko kum karta he takey high RPM pe oil ke zyada pressure se tapit cover full na ho jae aur oil air cleaner mein chala jae. aap us valve ko check karein wo aksar crack ho jata he ya phir uska hole bara ho jane se ye hota he.Ye meri Cultus mein bhi huwa tha aur mein ne change kya phir sub theek hogya. ye valve aapko old parts waloon k pass mile ga.Ye pics orginal nahi but only for example......
Kisi ko solution milaKa ni iAm facing too
Kindly share the solution experts
I am not able to find PCV Valve in Lahore, kindly recommend me a shop to get one for my Cultus 2003 carb engine
brother go to any suzuki parts dealer and tell him to give you blow-waal ( valve ) of cultus carby not a serious issue trust me even just ask your mechanic to fetch you one he will get for you but make sure to test if its working before instalation
I have clutus 2006 she is throwing oil in Air cleaner, mechinic has changed its PVC but the issue is still there, the engine is also making noice like tuk tuk after starting,Any one can guide what to do.
M Salar.
Which oil you are using?Carby Cultus do give noise at cold start if you are using wrong viscosity oil (20W-50) shift to 10W-40 and that noise problem will be solved. Minor oil mist in air filter housing is normal in case of carby Cultus you can't do anything about that i have tried all the solutions but that problem is still there and it's like that from the day this car was bought from showroom..
I haven't seen oil in Khyber's airfilter housing ever.
Its very normal ... its not an issue ... it happens becuase of blow by system in crank case ... exsess of air pressure build up in crank case is released from the blow valve .. and sometimes some of the oil also comes with that pressure .. its very normal .. your rings are perfect if there is no oil being burnt .. cheers
