get rid of that junk osaka coolant.
also how much are you driving? oil change interval?
you need API SG or SJ oil in your car (use the thinnest oil available in this category unless your engine is worn out). DO NOT use the newer oils in your car.
fuel filter replacement/service? this isnt normally needed, unless your tank is full of junk. we had a cuore from 2009 to 2018. never needed this.
tyre related costs are due to your driving conditions, and will be same for any car. 1500rs ka kaunsa tyre ata hai? if you are using reconditioned tires, i highly recommend you get new warranties tires.
radiator service: again why was it needed? I had it done only ONCE in the time we kept the cuore.
Foundations: the rubber foundations in the market are not good quality and have a tendency to wear out soon. specially the gearbox foundations.
