coure is most easy to work upon
jack up car on all wheels 4 place stands remove front wheels, disconnect wheels & steering ends 4 bolts from under carriage can take down whole engine loaded on front cross member ( gatri ). remove transmission change the clutch pack ( pressure plate, clutch plate & thrust bearing ) check for any leaking seals at fly wheel replace with NEW. couple the transmission back to engine roll back under the engine bay lift bolt back whole cross member etc etc back on wheels 4 hours tops
