URGENT HELP NEEDED.Cuore 2005 A/T. Rusted Radiator + Radiator water decreasing on daily Basis.also the AC is not working properly. Is it also due to the radiator problem ?what could be the possible solution? + Suggest some good mechanic in Lahore (preferably Walton area)
Toyota Walton
radiator should be changed. another option is to change radiator central part only which is easily available. after it use new cap and good coolant like Caltex etc. I guess water passage in engine is not rusted, this can make engine operate is higher temperature. AC is not related to radiator. maybe gas is low.
if i change the radiator then how much is it gonna cost me ?& from where should i get the radiator & its approx. cost ?
it will cost u from 4000 to 6000 from open market. depending on material, aluminum, copper etc.One came originally in my Cuore 2005 had plastic tanks. get cost from market. also call Toyota and if its reasonable, get it from them.
any recommendation for a good mechanic in Walton area (who can at least check the system, other than Toyota Walton)
members from Lahore can help.
If u want to get ur system checked, go to toyota walton. I dont think they will charge anything. Better ask them before
auto or manual?
Manual....
it is the pipe from reservoir bottle to radiator. it is leaking.remedy ?
so finally got the radiator repaired from this very point. this part is of plastic so got only this one replaced. costed me Rs.1700. radiator is OK now. NO heat up issue
NO response from the day i've posted in this thread
yes this pipe goes to reservoir bottle. this pipe is not under pressure. if plastic part of radiator is not cracked, u can buy a new pipe, take out battery and replace it.
so expensive.
cuore auto ka sirf 1st gare lag raha hai, kia problem ho sakti hai, suggest me can i go for repair or gear change?
get checked by experienced mechanic or Toyota. I hope just adjustment is required.
problem did not solve by adjustment
manufacturing date ?
2004, gear changed now
