rotational wheel wobble can only be due to few things... either the wheel hub is not seated squarely on the axel... the wheel hub is distorted or the axel is distorted.. or your wheel bearings are shot
you will have to open it up.. take of the tyre... try to get a run out of the axel shaft when it is rotating... if you can do that
