Aoa Pakwheelers.
Kindly tell me is civic vti 1.6 (1996 model) can support city aspire 1.5 ivtec engine (2009-2013 model) for more understanding I mentioned a comparative statement so that a crystal clear and accurate opinion is generated by expert pakwheelers. Waiting your prompt response
[TABLE]
[TR]
[TD="width: 425, bgcolor: transparent"]
HONDA CITY ASPIRE 1.5 I-VTEC SPECIFICATIONS
[/TD]
[TD="width: 756, bgcolor: transparent"]
HONDA CIVIC VTI 1.6 (1996) SPECIFICATIONS [/TD]
[/TR]
[TR]
[TABLE]
[TR]
[TD="width: 169, bgcolor: transparent"]
Boot Space [/TD]
[TD="width: 230, bgcolor: transparent"]
506 L [/TD]
[/TR]
[TR]
Kerb Weight [/TD]
1155 KG [/TD]
[/TR]
[TR]
No of Doors [/TD]
4 doors [/TD]
[/TR]
[TR]
Overall Height [/TD]
1480 mm [/TD]
[/TR]
[TR]
Overall Length [/TD]
4395 mm [/TD]
[/TR]
[TR]
Overall Width [/TD]
1695 mm [/TD]
[/TR]
[TR]
Wheel Base [/TD]
2550 mm [/TD]
[/TR]
[TR]
Cylinder Configuration [/TD]
In Line [/TD]
[/TR]
[TR]
Displacement [/TD]
1498 cc [/TD]
[/TR]
[TR]
Engine Power [/TD]
120 hp @ 5800 RPM [/TD]
[/TR]
[TR]
Fuel System [/TD]
EFI (Electronic Fuel Injection) [/TD]
[/TR]
[TR]
Volume of Engine [/TD]
1339 Cm3 (4.393045 ft) [/TD]
[/TR]
[TR]
Bore [/TD]
73 Cm3 (0.239501 ft) [/TD]
[/TR]
[TR]
Fuel Type [/TD]
Petrol [/TD]
[/TR]
[TR]
No of Cylinders [/TD]
4 [/TD]
[/TR]
[TR]
Torque [/TD]
143 Nm @ 4800 RPM [/TD]
[/TR]
[TR]
Valve Mechanism [/TD]
SOHC 16 Valves iVTEC [/TD]
[/TR]
[TR]
Steering Type [/TD]
Rack & Pinion with EPS [/TD]
[/TR]
[TR]
Suspension [/TD]
Front: Macpherson Strut, Rear: Torsion Beam [/TD]
[/TR]
[TR]
Tyres [/TD]
175/85/R15 [/TD]
[/TR]
[TR]
Wheel Size [/TD]
15 in [/TD]
[/TR]
[TR]
Brakes [/TD]
Front: Discs, Rear: Drums [/TD]
[/TR]
[TR]
Gearbox [/TD]
5-speed [/TD]
[/TR]
[/TABLE]
[/TD]
[TABLE]
[TR]
[TD="width: 164, bgcolor: transparent"]
Boot Space [/TD]
[TD="width: 178, bgcolor: transparent"]
379 L [/TD]
[/TR]
[TR]
Kerb Weight [/TD]
1030 KG [/TD]
[/TR]
[TR]
No of Doors [/TD]
4 doors [/TD]
[/TR]
[TR]
1390 mm (4.560367 ft) [/TD]
[/TR]
[TR]
4450 mm (14.59974 ft) [/TD]
[/TR]
[TR]
Overall Width [/TD]
1695 mm (5.561024 ft) [/TD]
[/TR]
[TR]
Wheel Base [/TD]
2620 mm (8.5958005 ft) [/TD]
[/TR]
[TR]
In-Line [/TD]
[/TR]
[TR]
Displacement [/TD]
1590 cc [/TD]
[/TR]
[TR]
Engine Power [/TD]
127 hp @ 6400 RPM [/TD]
[/TR]
[TR]
Fuel System [/TD]
EFI with VTEC [/TD]
[/TR]
[TR]
1590 cm3 (5.216 ft) [/TD]
[/TR]
[TR]
Bore [/TD]
75 mm (0.246 ft) [/TD]
[/TR]
[TR]
Fuel Type [/TD]
Petrol [/TD]
[/TR]
[TR]
4 [/TD]
[/TR]
[TR]
Torque [/TD]
144 Nm @ 5800 RPM [/TD]
[/TR]
[TR]
SOHC 16 valves [/TD]
[/TR]
[TR]
Steering Type [/TD]
Rack & Pinion with Hydraulic Pump [/TD]
[/TR]
[TR]
Suspension [/TD]
Front: Tube shocks and coil springs, Rear: Tube shocks and coil springs [/TD]
[/TR]
[TR]
Tyres [/TD]
185/65/R14 [/TD]
[/TR]
[TR]
Wheel Size [/TD]
14 in [/TD]
[/TR]
[TR]
Brakes [/TD]
Front: Ventilated Disc Rear: Drum [/TD]
[/TR]
[TR]
Gearbox [/TD]
5-speed [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
