A malfunction indicator lamp (MIL), commonly referred to as the "Check Engine Light" is an indicator of malfunction of the computerized engine management system. It is found on the instrument console of most automobiles. When illuminated, it is typically either an amber or red color. On vehicles equipped with OBD-II, the light has two stages: steady (indicating a minor fault such as a loose gas cap or failing oxygen sensor) and flashing (indicating a severe fault, that will eventually destroy the catalytic converter, such as a misfire). When the MIL is lit, the engine control unit stores a fault code related to the malfunction, which can be retrieved with a scan tool and used for further diagnosis. The malfunction indicator lamp is usually labeled with the text check engine, service engine soon, check engine soon, or a picture of an engine
