@baryar
(y) Nice to hear.
@bilalahm
Welcome bro! (y). Regarding the issues
Replace the servo + master cylinder of Cielo...works great. It costs around Rs.2000/= with fitting
a. Average CNG consumption within city is around 14 km/kg while on highway it is around 18 km/kg (at 100Km/H).
b. Average Petrol consumption within city is around 12Km/L while on highway it is around 14Km/L (at 100 Km/H)
- DOHC head swap's expenditure is as follows:
PARTS:
a. DOHC head + Manifolds ~ Rs.7500/=
b. Air Filter Box + Accessories ~ Rs.1500/=
c. MPFI ECM (to be arranged from Lahore) ~ Rs.4000/=
d. Timing Belt + Tensioner + Water Pump + Main Pulley + Generator Pully + Front Plate + Guide Pulley ~ Rs.5000/= (All Used)
e. It will be better to put in the high compression pistons of Twin Cam Engine for better results (9.5:1 compression). Note that the SOHC engine has 8.5:1 compression. ~ Rs.1800/=
f. It is also recommended to replace the engine side foundation and Clutch Plate + Pressure Plate + Clutch Bearing since older Clutch assembly won't last longer. ~ Rs.3000/=
LABOR:
a. Mechanic charges for the installation of DOHC head and other accessories ~ vary from mechanic to mechanic around Rs.5000/=
b. Electrician charges for making necessary alterations to the existing wiring for additional sensors including IAT (Intake Air Temperature) and Oxygen Sensor (O2 or Lambda sensor) ~ also vary from mechanic to mechanic around Rs.1500/=
If you purchase a complete kabli engine, it will cost around Rs.25000/= and you just have to pay for Labor as mentioned above. Offcourse, you will endorse new engine number in your registration book.
- You have to search the market :s
@asad1019
Point 3. above goes for you. (y)
