WAS
Sorry for the late reply.
It looks like head issue, either the hydraulic lashes are jammed or the valve/valve seats are gone. First of all, get a compression test done to isolate the problem, and if the head needs some job, better get a kabli head instead. Secondly, get the ignition system checked for any current leakage. BTW, code 15 in the above list means Coolent sensor is faulty, you should also get the coolant sensor checked for any problem. Always remember that the ECM and attached sensors will only work good when the engine is mechanically fit. About injector, since daewoo racer has single injector to feed all the four cylinders, it will throw 4 times more fuel than a single injector and as a result the fuel shower is quite dense.
