@kashmir1
Doctor sahab how is your car's engine working?
@javaid35
1. how the hydraulics (tapets) are serviced while overhauling the engine??
A: The head will be opened and hydraulic lifters will be removed. If they are in good shape, just washing with petrol will be sufficient. If they are worn-out, they needs to be replaced.
2. if the bore was on standard but has deeper pits when pistons are taken out then does then increasing the size of bore should be preferred or placing a new entire sleve is workable??
A: Sleeves are not recommended in the long run, better get it bored. If possible make
it
bored according to 1.6 Specs(increase bore from 76.5mm to 79mm) and put Optra's rings and pistons)
3. wats the price of following engine items:-
a. genuine ring set
b. genuine piston set
c. main baigons
d. valve set
A: Please refer to https://www.pakwheels.com/forumreply_az_TopicID!24322~ForumID!28~page!3~pw.html for contacts.
@asad1019
(y) looking nice!
