@baryar
Cielo door panels have same fitting as that of Racer. Better get these installed as they need no alterations at all.
@testdriver thanks a lot, any rough idea of price and place to find. i just need to change panels i dont wanna go for automatic want to keep it manual.
@tonton16
Automatic transmission cable for above mentioned models will definitely fit.
For that you have to:
Remove the power window switches and prepare a matching plastic to cover those areas
Cut a hole for the window lever in the panels.
If the above mentioned steps are not feasible and the existing panels are damaged, try arranging Racer door panels in a good shape and replace your existing with them.
For a second opinion, try getting in-touch with Faqeer Muhammad. If you need further contacts refer to page-3 of DFC.
thanks again sir testdriver do you think a cable of chevrolet cars can fit my ride...
and do you know what model of chevrolet is the subfleet of the racer..
model that we have here is:
1.optra
2.aveo
other is opel vectra
Yes I do know Chevrolet Optra is Daewoo Nubira and Chevrolet Aveo is Daewoo Lecetti, but they share same engine and Transmission only, other parts are very different.
Try getting Racer's/GTi's speedometer cable.
ok i will do that thanks again sir testdriver...i will let you know if i already got one thanks..
dude i had the same issue.... i had my door panels in pretty bad condition..... im redoin em maslf but dats kind of ok work...... if u want some real stuff to be done, go to "BABU MOHALLA" in rawalpindi saddar........ any "POSHISH WALA" will make em for you, the estimate wat i got was around 1000-1100.........
to sir testdriver somebody ask me if i have a turbo in my ride and i dont know why he ask me that ... do you know where the turbo is been place so i can check it if i have a silencer is still installed...sometimes i hear whistling sound after i accelerate...and its not that too loud im thinking if i have a turbo i need a BlowOff valve to maximize the air pressure...and do you have manual for cielo thanksss...
@sahill 22Thanks , what i get from ur msg is that the Poshish wal will like repair the orignal in 1100?, but i m trying to find something like of plastic as in other cars like city, corolla , cultus , santro or even of cialo and all other new cars, you know what i mean.but offcourse if i didnt find a good one i ll have to get it done from poshish wala.
No turbo!
The sound might be coming off the alternator.
oh ic thanks maybe thats the sound what im hearing...
thanks sir testdriver
yara the platic ones like in rollas or honda dont come in daewoo racer or cielo, they only have the card board ones and those are the ones that the poshish wala guy can make new for you...... or else u wnt to get the same ones repaired toh its totally ur choice.....
wow...never thought i would find a daewoo fan club
your welcome to the club sir FUELinjectedwheelybin
@sir testdriver i had a new problem when i step on the gas pedal my rpm goes wild from 1000RPM to 2000rpm to 3400rpm and my transmission dont change its gear if the dont step the pedal to hard and rev it to 4100rpm....this never happen to my last racer...and i already sprayed wd40 on the iAC to repair it but still dont do much i still have a very high RPM when i step the gas pedal....dont know whats the real problem
thankyou...post couple pics off one im doing up...
@fuelinjectedwheelybin
nice ride......... i likes
(y) Nice car!
It seems like TPS problem as I already mentioned in earlier reply to your post
Asalam U Alaikum Every One..
Yaar I Need Help Regarding Ma Daewoo..
Now A Days Its Taking Long Selfs To Start The Engine..
Even In Petrol It Takes A Bit Time..
What Must BE The Prob..??
Experts I Need Ur Help Plz..
@addy
Long starting time can be due to:
Distributor cap (The central carbon worn out)
Too retard timing
Plug/wire/distributor coil problem
Bad CO adjustment
Stuck IAC valve.
If the check engine light also lits, get the ECM scanned for any possible sensor problem. Also get the fuel filter checked it might be clogged and need replacement. If eveything is perfect, the fuel pump might have some problem.
As far as CNG is concerned, get the idle + idle mixture re-adjusted by your mechanic.
