Dear Daewoo experts,
I want your advice regarding a problem with my racer. The alternator produces 13.4 V at 2000 rpm with no load. This voltage drops to 12.1 V with full load condition (headlights, AC with full speed fan etc). I have already disconnected AC condensor fan as it further reduced the voltage to 11.9 V. I want your advice regarding:
An alternator is a combination of AC alternator, rectifier and voltage regulator. How can I isolate the faulty component?
Are these components are physically installed separately or in a single module?
Can a faulty component be repaired or replaced? For example if the voltage regulator is identified as faulty with AC alternator working fine, can only the regulator be repaired?
I am going to replace the battery as it has lasted for more than three years and now needs replacement. But in parallel, I also want that the charging system sould also be working fine.
Waiting for your advice.......thanks in advance for your valuable comments
