[quote="imtiaz.qureshi, post:23, topic:237220, full:true"]
What was the conclusion sir?
I had similar not starting problem in cold. It happened in Muree. It was started by loosening cam shaft a little bit and then tighten it later. When we reached back Lahore, it refused to start next morning. We changed the valves and rings but its now showing check engine light. Its error code P0016. Which is about crank and cam shaft not in sync. I checked A/C is not working on Idle. Please suggest some solution or reference to some OBD diagnostics expert in Lahore as our mechanic has limited knowledge about this. Thanks in advance
[/quote]
Hello,
Well for my brother's HiJet, it was valves issue which was replaced by Ishaq mechanic on Jamshed road. After replacing valves it started working perfectly.
I think you messed a bit with camshaft, now it might be out of alignment with the sensor. Not sure about Lahore, but you need a good mechanic who knows new cars. I hope someone here could recommend a good mechanic in Lahore city.
