its my pleasure.
hi i want to buy this car can any body tell me that cng can fitted in it or notplease tell me if there is another problem in miraAlso tell me its fuel consumption with AC and without AC
hii want to buy this car can anybody tell me is cng could fitted in it or notAlso tell me its fuel consumption with Ac or without Ac\Also tell me if ther is another problem
That will be a big problem on future , i believe in coming days local manufacturer will also start making the consumables parts for mirra
Its fuel economy is so high that u can run it easily on petrol........24 km/ ltr on high way with ac.........but u must go for manual transmission...........cus auto transmission its fuel economy is not so good and it is only 15 to 16 km/ltr as for as i know........u should not consider CNG as option in it...
look at this thread and all matter will be cleared
https://www.pakwheels.com/forums/member-opinions-suggestions/161261-diahtsu-mira
hmm After mkt intake system is an option post engine bay pictures.otherwise cut Stock element inner area n use foam in tht area
salam i want to know mira 2009 is available in manual transmition or notand its other features is automatic or not
can any body tell me what is difference between DAT and AT transmition of car
where cn i get the filter and spark plugs for 2007 mira in lahore ???
not sure of the air filter but i can help for the plugs if u can confirm me the engine code
indeed it is,ive seen the engine bay,its a pretty basic and easy diy
1300 each, ouch should last for a good hundred thousand kilometers at least
50-60k approx
same problem with my car i have suzuki kei turbo. . . last 1 months i tried to find out sparkplugs for my car NGK BPR5E, DENSO W16EPr-ui find it optimum zamzama , japan autos gul plaza and other market but ..............
ANY friend know about sparkplugs for my car please kindly help me . . thankx
i have the plugs for that,gave em to a member ady234 as well ,pm ing u the details
@Muhammed
Kindly msg your Engine Code to JZ and Inshallah he will have something in his stock for you, cheap than market rates.
ok sir
immad thankz for the ref bro, i already know the engine code for that,its eigther k6a or f6a,kei comes in these two engine varients
@ jz TOTALLY RIGHT ITS HAve F6A with TURBo
